Can someone help me?
I need to be able to loop through a WebTree that has Parent and Child branches. I need to look at the Child Branches for a Item I have placed in a tag. If the item is found "True" then I need to select (on the Server Side) that child node.
How do I do this?
You can use following recursion code to select a node anywhere in the tree based on search string value:
foreach (Node n in this.UltraWebTree1.Nodes)
FindNodeByTag("TagValue", n);
private void FindNodeByTag(string NodeTag, Node node)
foreach (Node n in node.Nodes)
if (n.Tag.ToString() == NodeTag)
n.Selected = true;
if (n.Nodes.Count > 0)
FindNodeByTag(NodeTag, n);
