Anyone can help on the following post?
Hello I have a Hierarchial UltraWebGrid with the second Band containing TemplatedColumn - with checkboxes. I'm trying to check all the checkboxes in the rows when the header checkbox is cheked.
can anyone help with the client side code.
i tried using the following :
function SelectAll(colIndex) {
//Selects all checkboxes in the grid
//var checked = cbSelectAll.checked;
for (i = 0; i < oGrid.Rows.length; i++) { true);
alert(oGrid.Row.getRow(i));
oGrid.Rows.getRow(i).getCell(colIndex).setValue(
but I feel like i;m not geting the child rows.
Genti
<igtbl:UltraWebGrid ID="grdData" runat="server" Browser="Xml" CaptionAlign="Top" Height="610px" Width="918px">
<Bands>
<igtbl:UltraGridBand AllowSorting="No" Indentation="0" IndentationType="Indented" RowSelectors="No" RowSizing ="Free">
<AddNewRow View="NotSet" Visible="NotSet"></AddNewRow>
</igtbl:UltraGridBand>
<igtbl:UltraGridBand>
<igtbl:TemplatedColumn Key="selItem" Type="CheckBox" AllowUpdate="Yes">
<HeaderTemplate>
<input id="cbSelectAll" name="cbSelectAll" type="checkbox" onclick="SelectAll(1)" />
</HeaderTemplate>
</Columns>
</Bands>
Hi all,
The code you are using should indeed give you the list of child rows for a particular grid row. For instance:
igtbl_getGridById("UltraWebGrid1").Rows.getRow(0).getChildRows()[0]
gives the html element for the first child of the first grid row. You can get the DOM object using something like:
var id = igtbl_getGridById("UltraWebGrid1").Rows.getRow(0).getChildRows()[0].id;var row = igtbl_getRowById(id);
http://help.infragistics.com/NetAdvantage/ASPNET/2011.2/CLR4.0/?page=Web_WebDataGrid_WebDataGrid.html
Additional samples demonstrating the features of these grids can be found at:http://samples.infragistics.com/aspnet/
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
Hi, gentis I get the same problem, do you get some solution for this? i try to select the checks on band(1) but I define the band(1) from code-behind
If Me.grdProcIncr.Bands(1).Columns.Exists(cCol.Key) = False Then Me.grdProcIncr.Bands(1).Columns.Insert(0, cCol) Me.grdProcIncr.Bands(1).Columns.Item("0").Width = System.Web.UI.WebControls.Unit.Pixel("20") Me.grdProcIncr.Bands(1).Columns.Item("0").AllowUpdate = Infragistics.WebUI.UltraWebGrid.AllowUpdate. YesEnd If
Do you know how to get the rows of band(1) with javascript???
function SelectAll(colIndex) { var checked = cbSelectAll.checked; //var rows; alert(oGrid.Rows.length); for (i = 0; i < oGrid.Rows.length; i++) { oGrid.Rows.getRow(i).getCell(1).setValue(checked); //rows = oGrid.Rows.getRow(i).getChildRows(); //rows.getCell(colIndex).setValue(checked); } } ///End of Header Select All functionality
regards.
