Hi all.
I am using UltraWebGrid v6.3, and i am generating columns and data at runtime
I have fixed a column in this grid by setting the property UseFixedHeaders="true"
when i manually adjust the column width and then do any server operation like save the altered data in the grid, then after page load the column headers and column data appears misaligned.
The above said misalignment does not occur if i am not fixing any columns ie making UseFixedHeaders="false"
can anyone from infragistics team or the members help me please?
This is possible behavior since this is old version of the toolset. We do not provide support for this version. The best and robust way to overcome this issue is as you upgrade to newer version /10.1 or 10.2 - which will be available soon/.
Please refer product life cycle here : https://ko.infragistics.com/support/product-lifecycle
Thank you.
