Is there a way to cancel the tab chage in the BeforeSelectedTabChange client-side event handler? I've looked through the documentation but can't sem to find it. I know that in the past (and for other controls) there were ways to cancel postbacks. This is basically what I am trying to do here.
I have the WebTab in a MS UpdatePanel. I have to enforce some validation on the first tab before the user can navigate to other tabs. I would like to handle this client-side to reduce the poastback delay time. If the data is not validated I want a JS alert box to display, then the tab change is basically ignored.
Thanks Matt. Following code worked for me perfectly.
oEvent.cancel =
true ;
Matt,
I have different scenario where different pages are being loaded in each tab.
I have a global Javascript variable in the tab page.But when I change the tab, the same variable doen't retain its value in beforetabchange event.
I am changing that variable in some other javascript method. I need to implement functionality where my application asks to save any unchanged data before tab change
Any suggestion ?
Pravin
Hi DreamKey,
you can cancel the BeforeSelectedTabChange event with the folloiwng line of BLOCKED SCRIPT
oEvent.cancel = true;
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %>
<%@ Register Assembly="Infragistics2.WebUI.UltraWebTab.v7.3, Version=7.3.20073.1043, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.UltraWebTab" TagPrefix="igtab" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" ><head runat="server"> <title>Untitled Page</title>
<script id="igClientScript" type="text/javascript"><!--
function UltraWebTab1_BeforeSelectedTabChange(oWebTab, oTab, oEvent){ //Add code to handle your event here. oEvent.cancel = true; }// --></script></head><body> <form id="form1" runat="server"> <div> <igtab:UltraWebTab ID="UltraWebTab1" runat="server"> <Tabs> <igtab:Tab Text="tab 0"> </igtab:Tab> <igtab:Tab Text="tab 1"> </igtab:Tab> <igtab:Tab Text="tab 2"> </igtab:Tab> <igtab:Tab Text="tab 3"> </igtab:Tab> </Tabs> <SelectedTabStyle BackColor="#FFC0C0"> </SelectedTabStyle> <ClientSideEvents BeforeSelectedTabChange="UltraWebTab1_BeforeSelectedTabChange" /> </igtab:UltraWebTab> </div> </form></body></html>
