110
Large spaces between menu items when items are added via code.
Hi all, I am having some difficulty with the layout of items on NavMenu. I am adding two items in code as follows ...
protected Infragistics.WebUI.UltraWebNavigator.UltraWebMenu VerticalMenu;
 VerticalMenu.WebMenuTarget = Infragistics.WebUI.UltraWebNavigator.WebMenuTarget.VerticalMenu;
VerticalMenu.Items.Clear();
VerticalMenu.Items.Add("Item1");
VerticalMenu.Items[0].TargetUrl=Server.UrlPathEncode("Form2.aspx");
VerticalMenu.Items[0].Style.Height = 30;
VerticalMenu.Items.Add("Item2");
VerticalMenu.Items[1].TargetUrl=Server.UrlPathEncode("Form2.aspx");
VerticalMenu.Items[1].Style.Height = 30;
VerticalNavAccessList.Add("VerticalMenu1",true);
VerticalMenu.HoverItemStyle.Cursor = Infragistics.WebUI.Shared.Cursors.Hand;
The problem I am having is that the menu items are widely spaced out with one being about one third the way down - the other about two thirds down. The height of the menu is set to that of the page. whereas I want them to display neatly at the top of the menu. Is there a property or something to enable this? The version I have is Infragistics2.WebUI.UltraWebNavigator.v7.1, Version=7.1.20071.1061.
The aspx has ...
<ignav1:UltraWebMenu id="VerticalMenu" runat="server" Width="150px" Height = "708px" ScrollImageBottom="ig_menu_scrolldown.gif"
     ScrollImageTopDisabled="ig_menu_scrollup_disabled.gif" ScrollImageBottomDisabled="ig_menu_scrolldown_disabled.gif"
     ScrollImageTop="ig_menu_scrollup.gif" SubMenuImage="ig_menuTri.gif">
    </ignav1:UltraWebMenu></DIV>
Any help here is really appreciated - I have tried all sorts of things to get this to work without success. I'm lost!
Karen.
