Hi all,
I am trying to capture scroll-bar events in xamWebGrid control;
I believe that there is a solution for this via ControlTemplate but I'm not sure how to do it
Can you help me out?
Thanks in advance
Exactly !
Thanks again
You won't be able to access them until the xamGrid has been loaded. As the Scrollbars come from the xamGrid's ControlTemplate.
-SteveZ
Thanks a lot for the very fast and accurate answer;
Just to ask something additional:
At the time of accessing the properties (VerticalScrollBar), they are null, and can't be assigned through code
(like:
IProvideScrollInfo test = this.newLicensesGrid;
test.VerticalScrollBar = new System.Windows.Controls.Primitives.ScrollBar();
Does that mean that I have to set them somewhere else (xaml) ?
Actually the Grid implements an Interface called IProvideScrollInfo that gives you access to the Vertical and Horizontal Scrollbars.
So you could use that.
