I just upgraded to NetAdvantage 2010 V2, and all existing WebGrids (and new ones created for testing) offset the Edit Cell from the Displayed Cell when "in-row" editing is allowed on specific cells (CellClickActionDefault=”Edit”).
The issue is with IE8 (Firefox works fine). Depending on how “Compatibility View” is set, the offset is different.
There is NO WAY we can ask all of our clients to set Compatibility View from the IE. BTW, why doesn’t the META tag for Compatibility View produce the same results as setting Compatibility View from IE?
Eventually we’ll convert to WebDataGrid and WebHierarchicalDataGrid; but, we need time. Currently we need to upgrade Infragistics to support Firefox.
Need help – desperately. Thanks.
Resolved.
The grid pages appeared within an outer FRAME page. This worked fine with NetAdvantage 2007; but, alas, no longer with 2010. Removing the FRAMEs seems to have resolved this problem.
