how can I hide a tool in the ribbonbar? I don`t find a property 'IsVisible' or 'Visibility'.
Regards
Marco
Works great . Thanks very much.
Milos
to find a tool by Id, you can simply use FindToolById() method of the ribbon:
string ribbons = "Pretraga";((RibbonTool)XamRibbon1.FindToolById(ribbons)).IsEnabled = false;
Hope this helps,
How I can set tools isEnable = false
I can not set directly XamRibbon1 tools isEnabled=false
something like this
private void XamRibbon1_Loaded(object sender, RoutedEventArgs e) { string ribbons = "Pretraga"; for (int i = 0; i<XamRibbon1.Tabs.Count; i++) { for (int j = 0; j<XamRibbon1.Tabs[i].Groups.Count ; j++) { for (int k = 0; k<XamRibbon1.Tabs[i].Groups[j].Tools.Count; k++) { if (XamRibbon1.Tabs[i].Groups[j].Tools[k].Id.ToString() == ribbons) { XamRibbon1.Tabs[i].Groups[j].Tools[k]. isEnabled=false ???????????? } } } } }
OK, thank you. I do this so.
Hi Marco,
Could you provide some more details about your scenario? Why do you need to hide a tool inside the ribbon?
There are strict guidelines from MSFT, describing how a Ribbon control should look and behave.
Hiding a tool in the Ribbon is against the rules - the tools on the ribbon must not change as a result of user interaction in the document.
You should disable the tools by setting their IsEnabled property to "false" instead of hiding them.
Hope that helps,
