180
Is it possible to use one zoombar to command two timelines?
My client wants to command (navigate in) two timelines using one common zoombar. Is it possible to develop this?
If yes, how can I do please?
Thanks.
  • 895
    Suggested Answer
    One way you can achieve this is by binding the ScrollPosition and ScrollScale properties of the Axis of one timeline to another. This way when one of the zoombar changes, the other will change too.
    <ig:XamTimeline x:Name="Timeline1">
    <ig:XamTimeline.Axis>
    <ig:NumericTimeAxis
      ScrollPosition="{Binding ElementName=Timeline2, Path=Axis.ScrollPosition, Mode=TwoWay}"
      ScrollScale="{Binding ElementName=Timeline2, Path=Axis.ScrollScale, Mode=TwoWay}" />
    </ig:XamTimeline.Axis>
    </ig:XamTimeline>
    <ig:XamTimeline x:Name="Timeline2">
    </ig:XamTimeline>
    If you want to use an external zoombar this is how it's done:
    </ig:XamTimeline>
    <ig:XamZoombar
      x:Name="Zoombar"
      ZoomChanged="Zoombar_ZoomChanged"/>
    </ig:XamTimeline>
    private void Zoombar_ZoomChanged(object sender, Infragistics.Controls.ZoomChangedEventArgs e)
    Timeline1.Zoombar.Range = e.NewRange;
    Timeline2.Zoombar.Range = e.NewRange;
     You might want to hide the default zoombars of the timelines:
    <Style x:Key="XamZoombarStyle" TargetType="ig:XamZoombar">
    <Setter
      Property="Visibility"
      Value="Collapsed" />
    </Style>
    <ig:XamTimeline
      x:Name="Timeline1"
      ZoombarStyle="{StaticResource XamZoombarStyle}"
