60
Howt to show X Axis Label in DateTime format?
Hello
I am trying to show X Axis Label values in datetime format like "2010-06-23 15:00" and I want to set step for X Axis as one hour.
My entity class has DateTime type property for X Axis. How to to this?
Following is my code :
private void SetChartStyle()
            Axis xAxis = new Axis();
            xAxis.AxisType = AxisType.PrimaryX;
            xAxis.AutoRange = false;
            xAxis.Label.Format = "{mm/dd/yy}";
            xAxis.Label.Angle = 45;
            webChart.Axes.Add(xAxis);
void server_GetGraphDataCompleted(object sender, GetGraphDataCompletedEventArgs e)
            List<GraphEntity> result = e.Result;
            Series seriesBT = new Series();
            seriesBT.Label = "BT";
            seriesBT.ChartType = ChartType.Line;
            seriesBT.DataMapping = "Label=Xcolumn;Value=Ycolumn";
            seriesBT.DataSource = result;
            webChart.Series.Add(seriesBT);
public class GraphEntity
     public DateTime  Xcolumn { get; set; }
     public Double Ycolumn { get; set; }
Furthermore, in order to set Minimum/Maximum Value in datetime format for X Axis, how to do it?
Thanks in Advance
Kwon
  • 816
    Suggested Answer
    I think this ScatterLine chart example should prove useful for you.
    XAML:
        <Grid x:Name="LayoutRoot" Background="White" Loaded="LayoutRoot_Loaded">
            <ig:XamWebChart Name="chart1">
            </ig:XamWebChart>
        </Grid>
    C#:
            private void LayoutRoot_Loaded(object sender, RoutedEventArgs e)
                DataPoint d = new DataPoint();
                d.ChartParameters.Add(new ChartParameter(ChartParameterType.ValueX, new DateTime(2010, 7, 6)));
                d.ChartParameters.Add(new ChartParameter(ChartParameterType.ValueY, 10));
                DataPoint d1 = new DataPoint();
                d1.ChartParameters.Add(new ChartParameter(ChartParameterType.ValueX, new DateTime(2010, 7, 7)));
                d1.ChartParameters.Add(new ChartParameter(ChartParameterType.ValueY, 20));
                DataPoint d2 = new DataPoint();
                d2.ChartParameters.Add(new ChartParameter(ChartParameterType.ValueX, new DateTime(2010, 7, 8)));
                d2.ChartParameters.Add(new ChartParameter(ChartParameterType.ValueY, 30));
                Series s1 = new Series();
                s1.ChartType = ChartType.ScatterLine;
                s1.DataPoints.Add(d);
                s1.DataPoints.Add(d1);
                s1.DataPoints.Add(d2);
                this.chart1.Series.Add(s1);
                Axis primXaxis = new Axis();
                primXaxis.AxisType = AxisType.PrimaryX;
                primXaxis.Label.Format = "{0:g}";
                primXaxis.AutoRange = false;
                primXaxis.Minimum = new DateTime(2010, 7, 5, 12, 0, 0).ToOADate();
                primXaxis.Maximum = new DateTime(2010, 7, 10, 12, 0, 0).ToOADate();
                primXaxis.Unit = new DateTime(1999,1,1,6,0,0).ToOADate() - new DateTime(1999,1,1,0,0,0).ToOADate(); // 6-hour interval
                this.chart1.Axes.Add(primXaxis);
    See also this MSDN article:
    Standard Date and Time Format Strings
