We have just migrated our project to from Silverligth 3 to Silverlight 4. We are using Silverlight DataVizualization 2010 vol1. Everything else except XamWebMenu is working fine. Is there any issue with the compatibility of XamWebMenu and Silverlight 4?
Have you applied the latest 10.1 Service Release?
Silverlight 4 support is provided with our 10.1 SR1+ versions.
HTH,
I have not applied the 10.1 Service Release. My Keys and Downloads page does not show me a Service release whice I can download. Can you please give me the link from where I can download it?
Thanks.
The equivalent of Infragistics.Silverlight.Datavisualization.Controls.v9.2 is InfragisticsSL4.DataVisualization.v10.2
So instead of the below 2 dlls -
Infragistics.Silverlight.DataVisualization.v9.2.dll
I need to refer just one i.e. InfragisticsSL4.DataVisualization.v10.2. Is this correct?
Yes, this is correct.
In Silverlight DV 10.2, the XamWebZoombar has been moved to a different assembly?
There were a number of name changes in 10.2 related to assembly names, namespaces and classes.
For instance: The XamWebZoombar has been renamed to XamZoomBar.
You could use our Version Utility to upgrade your solution without having to find and resolve all differences one by one.
You could find it under Start - > All Programs -> Infragistics -> NetAdvantage 2010.2 -> Version Utility
Hope that helps,
