Hi
I am trying to use Web Combo's in Suggest Mode to allow selection from fairly large datasets, this works well except for the following problem:
When typing in the combo the dropdown is displayed showing the selection valid from what has been typed in as expected, however I am finding that the display of the dropdown as the user types is either resetting the curser to the beginning of the text typed in or causing what has been typed in to become selected and deleted when the next character is typed.
Is there any way to prevent this happening as this is making the web combo in suggest mode unusable in practice?
can u tell me how u made the webcombo to display the dropdown with selection made from typing .
I have received the following in an email from Infragistics Support. but due to build errors when installing the hotfix and updating the application, I have removed the hotfix for now so have not been able to test this.
Dear Infragistics Customer,
The following WebCombo issue that you reported has been addressed in a hotfix release:BR28947 - Typing Fast in the combo and backspacing fast in between suggest requests causes strange behavior.
Hotfix Version(s):7.1.20071.1069 CLR 1.x, 7.1.20071.1069 CLR 2.0, 7.2.20072.1078 CLR 2.0, 7.3.20073.1052 CLR 2.0, 8.1.20081.2019 CLR 2.0, 8.1.20081.2019 CLR 3.5
As this was received before the latest release, it may be that the fix has been implemented in the release.
Ken
Did you find any solution for this. Even I am trying to fix this as its annoys the users. Please let me know if you have a fix
Thanks in advance
