1585
Set Expanded/CollapsedIcon Programatically
How would I set an icon for each programatically?
I create a new XamWebTreeItem as follows...
XamWebTreeItem xamWebTreeItem = new XamWebTreeItem();
xamWebTreeItem.Header = node.ItemName;
xamWebTreeItem.ExpandedIcon = ??
xamWebTreeItem.CollapsedIcon =??
I tried
 StreamResourceInfo r = Application.GetResourceStream(new Uri("/SilverlightApp;component/Images/test.jpg", UriKind.Relative));
                    BitmapImage bmp = new BitmapImage();
                    bmp.SetSource(r.Stream);
                    xamWebTreeItem.ExpandedIcon = bmp;
The image does not show up.
I can do this and the icon will show...
 <igTree:XamWebTree.ExpandedIconTemplate>
    <DataTemplate>
      <Image Source="/SilverlightApp;component/Images/test.gif" />
    </DataTemplate>
  </igTree:XamWebTree.ExpandedIconTemplate>
  • 1585
    Verified Answer
    Instead of setting the CollapsedIcon and ExpandedIcon to an object of type BitmapImage, I set it to a object of type Image and it worked. Problem solved.
