i am evaluating the xamPivotGrid and just a few questions are remaining:
Thanks,Dennis
When is the next service release going out?
Thanks Plamen,
working with just one cube is ok for a while.
Regards,Dennis
Hello Dennis,
If you mean the problem that occurs when more than one database is ran on the server it's due a bug in the request that is sent to the server. In this scenario the server expects some additional settings when querying data from databases that are not on the top but works well for the latest one. We have fixed it and it will be included in next service release.Thank you for your assistance while clarifying this problem. I hope that issue wouldn’t stop your work at all.
Regards.Plamen.
Hi Petar,
i still require asistance for the cube problem.
I am just checking if you got this worked out, and if you still require any assistance or clarification on the matter.
If this is what you were looking for please verify the answer so it helps other users as well.
Sincerely,Petar MonovDeveloper Support EngineerInfragistics Bulgariawww.infragistics.com/support
