40
Column Chooser Dialog Position Issue
I am using the column chooser in xamGrid (InfragisticsSL4.Controls.Grids.XamGrid.v10.2).  Is there a way to change its default position?  It currently displays in the center of the grid, which may be out of view of the user if the grid has a lot of rows.  Can it be positioned next to where the user clicked?
  • 1670
    Hello ryanr,
    First of all thank you for sharing that information with us. At the moment the Column Chooser displays always at the center of XamGrid, but there will be implemented a method that will allow you to specify a point in which to show the ColumnChooser in one of our next Service Releases. Hope that helps!
    Regards, Nikola.
