I am using export to excel from XamWebGrid. I did formatting for percentage and for doller signn like below
for example
tempvalue=24%
if (tempvalue.ToString().Contains("%"))
tempvalue = tempvalue.ToString().Replace(
Now i am getting value like -$4500. I want to format it as -$4500 and also when click . it should display -ve value in formula bar upper part of excel.
So please give any solution for that.
Nandkishor
We don't offer a way to get the formatted value.
However you can apply it yourself:
String.Format(culture, col.FormatString, value)
Hope this helps,
-SteveZ
Hi Stefana, Is there any way to get Formated Value from related cell?
if I have use same code as:cell.Value = 1234.123;cell.CellFormat.FormatString = "$0,000.00";
then is it possible that it may return us "$1,234.12" in runtime not in exported file in Excel.
Hi Nandu,
You can format Excel cell values by assigning an acceptable format string.
In your case you should use a string, similar to the one from the code snippet below, thus dispalying any number as currency.
cell.Value = -3000;
cell.CellFormat.FormatString = "$0000.00";
Save your Workbook as a file, open it, observe. I hope you get the target behavior.
Stefana
Is there any way to show negative values. like -$3000 in excel cell and when click on that value it should display -3000 in formula bar at upper side in excel sheet.
Nandu
