1585
XamOutlookBar Binding
I am trying to do some simple binding with the XamOutlookBar.
The control seems to be binding but for some reason it looks as if the DataTemplates are not being applied. Here is my code... this is a very simple example I am working with...I must have missed something with the binding, I have used other controls from Infragistic and never had this issue...
Instead of using the bound object property respectively it just shows the object path... Here is a screen shot of the rendered page...
Here is my XAML
<UserControl xmlns:ig="">schemas.infragistics.com/xaml"  x:Class="SilverlightApplication1.MainPage"
    xmlns="">schemas.microsoft.com/.../presentation"
    xmlns:x="">schemas.microsoft.com/.../xaml"
    xmlns:d="">schemas.microsoft.com/.../2008"
    xmlns:mc="">schemas.openxmlformats.org/.../2006"
    mc:Ignorable="d"
    HorizontalAlignment="Stretch"
    VerticalAlignment="Stretch"
    <UserControl.Resources>
        <DataTemplate x:Key="group2Template">
            <ig:OutlookBarGroup>
                <ig:OutlookBarGroup.HeaderTemplate>
                    <DataTemplate>
                        <TextBlock Text="{Binding ItemName}" />
                    </DataTemplate>
                </ig:OutlookBarGroup.HeaderTemplate>
                <ig:OutlookBarGroup.ContentTemplate>
                    <DataTemplate>
                    </DataTemplate>
                </ig:OutlookBarGroup.ContentTemplate>
            </ig:OutlookBarGroup>
        </DataTemplate>
    </UserControl.Resources>
    <Grid x:Name="LayoutRoot">
        <ig:XamOutlookBar x:Name="test"
                 DefaultGroupsContainer="{StaticResource group2Template}"
          </ig:XamOutlookBar>
    </Grid>
</UserControl>
Any my code behind....
    public partial class MainPage : UserControl
        public MainPage()
            InitializeComponent();
            MockModel mm = new MockModel();
            for(int i = 0; i < 3; i++){
                MockNode mn = new MockNode();
                mn.ItemName = String.Format("Node {0}", i);
                mm.Nodes.Add(mn);
            this.test.GroupsSource = mm.Nodes;
    public class MockModel
        public ObservableCollection<MockNode> Nodes;
        public MockModel()
            Nodes = new ObservableCollection<MockNode>();
    public class MockNode
        public string ItemName {get;set;}
        public string ImageURL {get;set;}
