1585
Access control inside datatemplate
I am two-way databinding to create my Outlook Groups and the content for each group respectively.
How can I programatically access the controls inside the group? Since they are databound, when I look at my xamOutlookBar.Groups content it doesn't give me the controls but the actual Model that I am using for the binding.
I tried to use VisualTreeHelper but didnt have any luck with that.
Ideas?
  • 5595
    You are right, the OutlookBarGroup object's Content returns the corresponding data item from the data source your are binding to.
    Using the VisualTreeHelper could be used to access the controls defined with the DataTemplate.
    However, note that those controls are only accessible by the VisualTreeHelper when the Group is selected. Is that your case?
    HTH,
