I am trying to in the IsExpanded property to be bound two way so that the tree stays persistent throughout the life of the application.
<igTree:XamTreeItem MouseLeftButtonDown="XamTreeItem_MouseLeftButtonDown" Visibility="{Binding Path=Visible, Mode=TwoWay}" IsExpanded="{Binding Path=IsExpanded, Mode=TwoWay}" IsSelected="{Binding Path=IsSelected, Mode=TwoWay}" PropertyChanged="XamTreeItem_PropertyChanged"/>Initially I have the value set as TRUE.But after binding happens somehow all the values are false...I am never setting IsExpanded anywhere in code except the constructorwhich initializes it to TRUE.The only time the value can be changed is on the PropertyChanged event for the XamTreeItemThis code is executed for this...private void XamTreeItem_PropertyChanged(object sender, System.ComponentModel.PropertyChangedEventArgs e){ XamTreeItem xamTreeItem = (XamTreeItem)sender; if (e.PropertyName == "IsExpanded") { ((TreeViewItemInstance)xamTreeItem.Data).IsExpanded = xamTreeItem.IsExpanded; }}So I am not sure how things are getting set to false. When I initially create my collection that will be bound as the model to bind to each item's IsExpanded is set to TRUE. Then after the initial binding somehow they all get set to FALSE. Any ideas? I also thought I could use the persistence class to maintain a property of a control throughout its life... I tried this... <igTree:XamTreeItem MouseLeftButtonDown="XamTreeItem_MouseLeftButtonDown" Visibility="{Binding Path=Visible, Mode=TwoWay}" IsSelected="{Binding Path=IsSelected, Mode=TwoWay}" PropertyChanged="XamTreeItem_PropertyChanged"> <ig:PersistenceManager.Settings> <ig:PersistenceSettings SavePersistenceOptions="OnlySpecified"> <ig:PersistenceSettings.PropertySettings> <ig:PropertyNamePersistenceInfo PropertyName="IsExpanded" Options="PropertyPath"/> </ig:PersistenceSettings.PropertySettings> </ig:PersistenceSettings> </ig:PersistenceManager.Settings> </igTree:XamTreeItem> This did not work either...
when i click an item in xamtree that item information will display in textbox. Tell me how to bind?
How to bind the data from database from xam tree to textbox or textblock
I tried to reproduce your results with the following:
<ig:XamTree x:Name="tree" DisplayMemberPath="Name">
<ig:XamTree.DefaultItemsContainer>
<DataTemplate>
<ig:XamTreeItem
ItemsSource="{Binding Path=Stuff}"
</DataTemplate>
</ig:XamTree.DefaultItemsContainer>
</ig:XamTree>
With a data class defined
public class DataObject : INotifyPropertyChanged
public Visibility Visible { get; set; }
private bool _isExpanded;
public bool IsExpanded
get { return this._isExpanded; }
set
if (this._isExpanded != value)
this._isExpanded = value;
if (this.PropertyChanged != null)
this.PropertyChanged(this, new PropertyChangedEventArgs("IsExpanded"));
public string Name { get; set; }
public ObservableCollection<DataObject> Stuff { get; set; }
#region INotifyPropertyChanged Members
public event PropertyChangedEventHandler PropertyChanged;
#endregion
And the list built like
public MainPage()
InitializeComponent();
List<DataObject> list = new List<DataObject>();
DataObject d = new DataObject();
d.Name = "object 1";
d.Visible = Visibility.Visible ;
d.IsExpanded = true;
d.Stuff = new ObservableCollection<DataObject>();
d.Stuff.Add(new DataObject() { Name = "object 2" });
list.Add(d);
tree.ItemsSource = list;
And did not see the same behavior. The expanded node was expanded when the page rendered and i validated that changing is expanded via the ui changed the underlying data object.
Are you adding your data piecemeal or all prior to binding? If you add the top level node prior to there being any children the tree may not know it could be expanded? Its only a guess on to what might be happening.
