I have a requirement to highlight the point in Line chart based on selected ComboBox value. For example the selected value in combo box is "2010" then chart should be like this.
Does Infragistic chart support this feature? Is there any work around to do this?
I would like to ask is this feature has been added to controls or we still have to do it manually?
We have a requirement, where we want to addd shading in ploat area behind the lines. so there will be multiple areas/shadings.
Thanks.
Hello Max,
I need your assistance on one more requirements of Chart. Kindly see my post here and help me to complete my requirements.
Thank You Max.....it rocks
You can remove the border from the column with a small data template:<igChart:Series x:Name="columnSeries" Stroke="Transparent" ChartType="Column" AxisY="y2" AxisX="x1" UseDataTemplate="True"> <igChart:Series.DataPointStyle> <Style TargetType="igChart:ColumnChartDataPointTemplate"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="igChart:ColumnChartDataPointTemplate"> <Rectangle Fill="{TemplateBinding Fill}"/> </ControlTemplate> </Setter.Value> </Setter> </Style> </igChart:Series.DataPointStyle>
Unfortunately, xamwebchart doesn't support null handling, but this is something you might want to consider using the DataChart control for.
Here is my code for creating above chart for your reference.
<igChart:XamWebChart x:Name="theChart" HorizontalAlignment="Stretch" Background="#FFEAEAEA" VerticalAlignment="Stretch" Margin="0" > <igChart:XamWebChart.Scene> <igChart:Scene> <igChart:Scene.GridArea> <igChart:GridArea BorderBrush="Black" BorderThickness="1, 0, 0, 2" /> </igChart:Scene.GridArea> </igChart:Scene> </igChart:XamWebChart.Scene> <igChart:XamWebChart.Series> <igChart:Series x:Name="lineSeries" ChartType="Line" AxisX="x1" AxisY="y1" > <igChart:Series.DataPoints> <igChart:DataPoint Value="2.3" Label="2007"> <igChart:DataPoint.Marker> <igChart:Marker Type="None" Format="" /> </igChart:DataPoint.Marker> </igChart:DataPoint> <igChart:DataPoint Value="2.8" Label="2008"> <igChart:DataPoint.Marker> <igChart:Marker Type="None" Format="" /> </igChart:DataPoint.Marker> </igChart:DataPoint> <igChart:DataPoint Value="2.9" Label="2009"> <igChart:DataPoint.Marker> <igChart:Marker Type="None" Format="" /> </igChart:DataPoint.Marker> </igChart:DataPoint> <igChart:DataPoint Value="3.2" Label="2010" > <igChart:DataPoint.Marker> <igChart:Marker Type="None" Format="" /> </igChart:DataPoint.Marker> </igChart:DataPoint> <igChart:DataPoint Value="2" Label="2011"> <igChart:DataPoint.Marker> <igChart:Marker Type="None" Format="" /> </igChart:DataPoint.Marker> </igChart:DataPoint> <igChart:DataPoint Value="2.1" Label="2012" > <igChart:DataPoint.Marker> <igChart:Marker Type="None" Format="" /> </igChart:DataPoint.Marker> </igChart:DataPoint> <igChart:DataPoint Value="2.1" Label="2013" > <igChart:DataPoint.Marker> <igChart:Marker Type="None" Format="" /> </igChart:DataPoint.Marker> </igChart:DataPoint> </igChart:Series.DataPoints> </igChart:Series> <igChart:Series x:Name="columnSeries" ChartType="Column" Stroke="Transparent" AxisY="y2" AxisX="x1"> <igChart:Series.DataPoints> <igChart:DataPoint Value="0" /> <igChart:DataPoint Value="0" /> <igChart:DataPoint Value="0" /> <igChart:DataPoint Value="1" /> <igChart:DataPoint Value="0" /> <igChart:DataPoint Value="0" /> <igChart:DataPoint Value="0" /> </igChart:Series.DataPoints> <igChart:Series.Fill> <LinearGradientBrush Opacity=".2"> <GradientStop Color="#FFBF00" Offset="0.541"/> <GradientStop Color="#FFBF00" Offset="1"/> </LinearGradientBrush> </igChart:Series.Fill> </igChart:Series> </igChart:XamWebChart.Series> <igChart:XamWebChart.Axes> <igChart:Axis AxisType="PrimaryX" Name="x1"> <igChart:Axis.MajorGridline> <igChart:GridlineGroup Visibility="Collapsed" /> </igChart:Axis.MajorGridline> <igChart:Axis.MinorGridline> <igChart:GridlineGroup Visibility="Collapsed" /> </igChart:Axis.MinorGridline> </igChart:Axis> <igChart:Axis AxisType="PrimaryY" Name="y1"> <igChart:Axis.MajorGridline> <igChart:GridlineGroup Visibility="Collapsed" /> </igChart:Axis.MajorGridline> <igChart:Axis.MinorGridline> <igChart:GridlineGroup Visibility="Collapsed" /> </igChart:Axis.MinorGridline> </igChart:Axis> <igChart:Axis AxisType="SecondaryY" Minimum="0" Maximum="1" Unit="1" AutoRange="False" Name="y2" Visibility="Collapsed" > <igChart:Axis.MajorGridline> <igChart:GridlineGroup Visibility="Collapsed" /> </igChart:Axis.MajorGridline> <igChart:Axis.MinorGridline> <igChart:GridlineGroup Visibility="Collapsed" /> </igChart:Axis.MinorGridline> </igChart:Axis> </igChart:XamWebChart.Axes> <igChart:XamWebChart.Legend> <igChart:Legend Visibility="Collapsed" /> </igChart:XamWebChart.Legend> </igChart:XamWebChart>
