955
Best way to configure custom settings.
Infragistics.Controls.Charts.ColorMapper can be set on a TreeMap instance in the xaml.
If I wanted to set properties on the ColorMapper object manually, what is the best way to do it.
It seems like it is all manual. I would have to read the ToColor, FromColor and then grab the configured Color mapper and set the custom values
ColorMapper cm = this.TreeMap.ValueMappers[0] as ColorMapper;
cm.From = (Media.Color)System.Windows.Media.ColorConverter.ConvertFromString("Pink");
cm.To = (Media.Color)System.Windows.Media.ColorConverter.ConvertFromString("Black");
Is this the best way to do it?
thanks
  • 895
    Here is a ColorMapper definition in XAML code:
    <ig:ColorMapper
        ValueTypeName="Product"
    ValuePath="StandardCost"
    TargetProperty="Fill"
    MappingMode="AllNodes"
    From="Pink"
    To="Black" />
    Usually the code-behind approach is used if the ColorMapper is going to change during runtime.
    Also in XAML you can use data binding more easily.
  • 605
    If you want to create a color mapper in the c# code you need to do something like this
    ColorMapper colorMapper = new ColorMapper() { ValueTypeName = "Order", TargetProperty = "Fill", ValuePath = "Value", From = Colors.Red, To = Colors.Yellow};
    this.myTreemap.ValueMappers.Add(colorMapper);
    If you already have a defined color mapper you may do something like this:
    ColorMapper colorMapper = this.myTreemap.ValueMappers[0] as ColorMapper;
    colorMapper.From = Colors.Orange;
    colorMapper.To = Colors.Purple;
