I'm binding the ultrawegrid alternately to two ObjectDataSources. The columns and headers are set in the _InitializeLayout event if the grid. When the datasourceID of the gris is changed, it loses all the column settings? Is there a way to retain this? The two Object data sources return the same columns with the same names. Why does this happen? Is there a way to retain the header settings?
Thank you.
