160
PersistenceManager.Save Method, Save setting on diffrent location.
Hi every one,
 I try to save XamWebGrid setting on a different location (for example “C:\ABC” Folder).
I use this code , but I cannot able to save memoryStream on a different location. How I can do this? Without open any Dialog Box.
public static void SaveSetting(DependencyObject obj, string fileName) {
      try {
        if (isSettingLoading == false) {
          PersistenceSettings persistaenceSetting = new PersistenceSettings();
          persistaenceSetting.SavePersistenceOptions = Infragistics.Silverlight.Primitives.PersistenceOption.AllButIgnored;
          MemoryStream memoryStream = PersistenceManager.Save(obj, persistaenceSetting);
          //string filePath = @"C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\14\TEMPLATE\XML\" + fileName;
          using (IsolatedStorageFile iso = IsolatedStorageFile.GetUserStoreForApplication()) {
            if (iso.FileExists(fileName))
              iso.DeleteFile(fileName);
            using (IsolatedStorageFileStream stream = new IsolatedStorageFileStream(fileName, FileMode.OpenOrCreate, iso)) {
              stream.Write(memoryStream.ToArray(), 0, (int)memoryStream.Length);
              stream.Close();
          memoryStream.Close();
          persistaenceSetting = null;
      catch (Exception ex) {
        MessageBox.Show(ex.Message, "CommonMethods.SaveSetting", MessageBoxButton.OK);
