Greetings,
I was having issues with a WebAsyncRefreshPanel not working in a Microsoft SharePoint environment, namely that the postbacks from controls within the panel were only occurring once, with any subsequent attempts failing. After reading the following post...
http://forums.archive.infragistics.com/readmessage?id=%3C2c08997$32849066$2c1d78@news.infragistics.com%3E&group=infragistics.products.netadvantage.aspnet.webasyncrefreshpanel
I thought I should share another possible solution that has worked for me. I did not feel comfortable making modifications to the SharePoint OOB files, but was able to make the WARP work by doing the following:
1. Set the RefreshComplete property of the WARP to point to my own custom js function 2. Implement the custom js function as follows... function warp_RefreshComplete(){ try { _spFormOnSubmitCalled = false; } catch(e) { } }
With this implementation, all postbacks are working from within my WARP. Anyway, just wanted to share in case anyone else was having the same problem.
Thanks!
