355
Animation is clunky when dynamically loading a user control
I'm dynamically loading different UserControls based on the TileState of a TilePane within my xamTileView control. I'm loading the control based on the xamTileView.MaximizedStateChanged event, so I thought the entire animation would be finished by then. Everything was working great until I started adding some business logic to one of the UserControls. Now, the first time that TilePane enters the state where that user control will load, the animation has disappeared. It's almost like the animation has been trumped by loading the UserControl.
I'd realy like to keep the animation on the first maxizing of a tile... any ideas on how I could address this? Maybe there's a better event to trap?
  • 3071
    Verified Answer
    The animation may disappear because the user control causes additional layout changes after adding an additional business logic initialization.
    You can add this logic in AnimationCompleted event-handler.
    This sample code demonstrates how to work with AnimationCompleted event:
    TilePane _tile;
    void tileView_MaximizedStateChanged(object sender, TileStateChangedEventArgs e)
    TilePane pane = e.Element as TilePane;
    if (pane.Name == "tile11")
        _tile = pane;
    if (e.NewState == TileState.Maximized)
    // load some user control when the tile is maximized
    _tile.Content = new OutlookBar();
    // add an event handler to the AnimationCompleted event
    AnimatedPanel panel = pane.Parent as AnimatedPanel;
          panel.AnimationCompleted += Panel_AnimationCompleted;
    else
          _tile.Content =
    null;
    void Panel_AnimationCompleted(object sender, EventArgs e)
    AnimatedPanel panel = sender as AnimatedPanel;
      panel.AnimationCompleted -= Panel_AnimationCompleted;
    // put the UC initialization here
    _tile.Content = "AnimationCompleted";
    Marin
