25
Using the xamPivotGrid with ADOMD
Hi!
First of all, appologizes for the verbosity of this post, hope you'll bare with me :-)
I'm currently involved in an web application that uses ADOMD to query olap cubes. As known, the ADOMD returns results in form of the CellSet. We then convert this cellset into a more "flat" structure which we use in a custom build grid (asp.net / ajax). We query the cubes by executing our own build MDX-queries (which are based on our own Report/MDX layout format, created in another tool). This application is not a "cube browsing" application, but a simplified "report-viewer with drill-down features". One of the main focus is performance and simplicity of use.
We are intersted in moving our front-end part of our application towards your new pivot grid, and therefore I'm wondering if you have any suggestions to how such and application could be adjusted to meet the requirements of the xamPivotGrid.
So my questions are:
1) Could ADOMD be used as a datasource for the PivotGrid (I reccon since the native CellSet isn't serializable, it's not a good candidate for a datasource in a Silverlight application), or do we have to "convert" the ADOMD CellSet into a FlatDataSource. If yes, do you have any examples on how to go about this task? I'm especially interested in the dynamic-issue of the data, meaning we have no idea of how the query data looks before it is executed.
2) We need to have full control over the MDX queries that are executed. By this I mean for example when a user drills down on a member, we would have to catch an event and build our own query, execute it (through adomd), parse the result and update only the part of the grid that was effected (=add children of the drilled-on member). Does the xamPivotGrid support such a scenario?
3) Do we have full control over the PivotGrid's apperance? Meaning, can we eliminate things like the "Drop Columns Here", "Drop Filters Here", "Drop Rows Here" etc, fields? We just want to show the results in a clean grid-like view. (With the only allowable user-actions to be Drill-down (on rows), Sort (by columns) and clicking a cell (for opening for example a sub-report or other detailed information).
Thank you for your time!
Regards
Jon
