I was expecting this to be fairly straightforward but not sure what's wrong. I am using version 10.2.20102.2005. Here is my sample code
XAML:
<ig:XamGrid x:Name="igGrid" AutoGenerateColumns="False" Height="150"> <ig:XamGrid.Columns> <ig:TextColumn Key="WorksheetID" HeaderText="Worksheet Id"/> <ig:TextColumn Key="LineItemID" HeaderText="LineItem Id"/> <ig:TextColumn Key="GOID" HeaderText="GOID"/> </ig:XamGrid.Columns>
</ig:XamGrid>
C# code:
public void FetchMyWorkSheets() { List<Worksheet> worksheets = new List<Worksheet>(); for (int i = 0; i < 10; i++) { Worksheet ws = new MyWorksheet(); ws.WorksheetID = i; ws.LineItemtID = i * i; ws.GOID = i + i; worksheets.Add(ws); } igGrid.ItemsSource = worksheets; }
public class Worksheet { public int WorksheetID { get; set; } public int LineItemtID { get; set; } public int GOID { get; set; } }
Exception:
Following exception is thrown at line igGrid.ItemsSource = worksheets;
Infragistics.Controls.Grids.InvalidColumnKeyException was unhandled by user code Message=The following key(s) do not correspond with the DataSource: "LineItemID". If you'd like to add additional columns, please use the UnboundColumn type. StackTrace: at Infragistics.Controls.Grids.RowsManager.InitializeData() at Infragistics.Controls.Grids.RowsManager.SetupDataManager() at Infragistics.Controls.Grids.RowsManager.EnsureDataManager() at Infragistics.Controls.Grids.RowsManager.OnItemsSourceChanged() at Infragistics.Controls.Grids.RowsManager.set_ItemsSource(IEnumerable value) at Infragistics.Controls.Grids.XamGrid.ApplyItemSource(IEnumerable itemSource) at Infragistics.Controls.Grids.XamGrid.ItemsSourceChanged(DependencyObject obj, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.RaisePropertyChangeNotifications(DependencyProperty dp, Object oldValue, Object newValue) at System.Windows.DependencyObject.UpdateEffectiveValue(DependencyProperty property, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, ValueOperation operation) at System.Windows.DependencyObject.SetValueInternal(DependencyProperty dp, Object value, Boolean allowReadOnlySet) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at Infragistics.Controls.Grids.XamGrid.set_ItemsSource(IEnumerable value) at Jenzabar.EX.SLTestPage.FetchMyWorkSheets() at Jenzabar.EX.SLTestPage.btnFetch_Click(Object sender, RoutedEventArgs e) at System.Windows.Controls.Primitives.ButtonBase.OnClick() at System.Windows.Controls.Button.OnClick() at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e) at System.Windows.Controls.Control.OnMouseLeftButtonUp(Control ctrl, EventArgs e) at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, String eventName) InnerException:
I've had a similar problem with the XamGrid. I've found that properties of the object need to have proper "Get" methods defined for the binding to work. Make sure that the columns you want to use are not public properties but instead expose Get and Set methods.
If you don't specify the column, and have AutoGenerateColumns set to true. Does that column appear?
-SteveZ
Ok, I messed up with a typo in my sample code but ironically I got the same exception that I am getting in my actual code. Here are code snippets and info from actual code I am working on. In my XAML Code below I have both Infragistics and MS grids side by side and binding them to same data source.
<ig:XamGrid x:Name="igGrid" AutoGenerateColumns="False" Height="150"> <ig:XamGrid.Columns> <ig:TextColumn Key="WorksheetID" HeaderText="Worksheet Id"/> <ig:TextColumn Key="LineItemID" HeaderText="LineItem Id"/> <ig:TextColumn Key="GOID" HeaderText="GOID"/> </ig:XamGrid.Columns> </ig:XamGrid> <data:DataGrid x:Name="dg" Style="{StaticResource grid}" AutoGenerateColumns="False" HeadersVisibility="Column"> <data:DataGrid.Columns> <data:DataGridTextColumn Binding="{Binding WorksheetID}" Header="Worksheet Id" IsReadOnly="True" /> <data:DataGridTextColumn Binding="{Binding LineItemID}" Header="LineItem Id" /> <data:DataGridTextColumn Binding="{Binding GOID}" Header="GOID" /> </data:DataGrid.Columns> </data:DataGrid>
My C# code binds both grids to same data source. MS grid works without any problem but I get the same exception for infragistics.
C# Code:
this.dg.ItemsSource = e.ResolvedEntities; this.igGrid.ItemsSource = e.ResolvedEntities;
ResolvedEntities is a List<WorksheetLineItem> and WorksheetLineItem is a complex type. See screenshot below. Please note the immediate window shows that ResolvedEntities is populated.
And finally the full exception details.
Infragistics.Controls.Grids.InvalidColumnKeyException was unhandled by user code Message=The following key(s) do not correspond with the DataSource: "WorksheetID". If you'd like to add additional columns, please use the UnboundColumn type. StackTrace: at Infragistics.Controls.Grids.RowsManager.InitializeData() at Infragistics.Controls.Grids.RowsManager.SetupDataManager() at Infragistics.Controls.Grids.RowsManager.EnsureDataManager() at Infragistics.Controls.Grids.RowsManager.OnItemsSourceChanged() at Infragistics.Controls.Grids.RowsManager.set_ItemsSource(IEnumerable value) at Infragistics.Controls.Grids.XamGrid.ApplyItemSource(IEnumerable itemSource) at Infragistics.Controls.Grids.XamGrid.ItemsSourceChanged(DependencyObject obj, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.RaisePropertyChangeNotifications(DependencyProperty dp, Object oldValue, Object newValue) at System.Windows.DependencyObject.UpdateEffectiveValue(DependencyProperty property, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, ValueOperation operation) at System.Windows.DependencyObject.SetValueInternal(DependencyProperty dp, Object value, Boolean allowReadOnlySet) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at Infragistics.Controls.Grids.XamGrid.set_ItemsSource(IEnumerable value) at Jenzabar.EX.SLTestPage.WorksheetLineItems_PendingEntityListResolved(Object sender, PendingEntityListResolvedEventArgs`1 e) at IdeaBlade.EntityModel.RelatedEntityList`1.OnPendingEntityListResolved(RelatedEntityList`1 resolvedEntities) at IdeaBlade.EntityModel.ListEntityReference`1.InformPendingEntityListOfRealEntityList(RelatedEntityList`1 realEntityList) at IdeaBlade.EntityModel.ListEntityReference`1.QueryCallback(EntityQueryOperation op) at IdeaBlade.EntityModel.EntityQueryOperation.IdeaBlade.EntityModel.IHasAsyncEventArgs.OnCompleted() at IdeaBlade.EntityModel.AsyncProcessor`1.<>c__DisplayClass2.<.ctor>b__0(TArgs args) at IdeaBlade.EntityModel.AsyncProcessor`1.Signal() at IdeaBlade.EntityModel.AsyncProcessor`1.<Execute>b__5(Object x) InnerException:
This is because your WorkSheet object doesn't have "LineItemID" property. Note that you have "LineItemtID" (the "t" before ID) defined in WorkSheet.
Hope this helps
