Hi All,
We are using Infragistics NetAdvantage 2006 Volume 3 CLR 2.0
I'm using a Webgrid with editble columns it is working fine in IE but in Firefox the columns are becoming totaly un-editable i.e it is appearing as a simple grid.
I wanna know is there any solution or hotfix for this problem
Please download a trial version of the latest NetAdvantage version and test using it.
Magued
Hi
We have developed lot of applications using the same 2006 infragistics now migration will eat up lot of time and these applications are used on daily basis.
So, I just wanna is there any alternative or any fix for this.
Also if somebody else has implemented same version on Firefox then how could be it done
Please review the following link:
http://forums.infragistics.com/forums/p/37767/221709.aspx
Also please review our supported environments link:
http://ko.infragistics.com/support/supported-environments.aspx#SupportedEnvironmentUnder environments, if you are using a later version of FireFox then it will only be supported by a later version of NetAdvantage.
