HI All,
This is my second day get touch silverlight and XamMap, Here is what I am looking for :
I am receiving my trucks' latitude and longitude every 15 mins. I need to show it on a road level maps.
can I do it with xamMap ?
How can I do it ?
Your help is very appreciated.
Ray
Hi,The best way to go about this might be to use a geo imagery layer and put a symbol layer on top of it to represent the trucks.You can find information here: http://help.infragistics.com/NetAdvantage/DV/2010.2/CLR4.0/?page=xamWebMap_Geo-Imagery_Integration.htmlabout how to configure the various geo imagery options of the xamMap.Below is a small example that moves a truck dot around randomly on top of the geo-imagery.You will notice the one unfriendly part of this sample is that the 2 map layers don't pan at the same rate when you are panning the map using a mouse drag.I believe keeping these pans synchronized is something we are planning on adjusting soon.This sample uses OpenStreetMaps, but the principle is that same for the other imagery sources:The xaml:
<igMap:XamMap x:Name="theMap" > <igMap:XamMap.MapTileSource > <igMap:OpenStreetMapTileSource/> </igMap:XamMap.MapTileSource> <igMap:XamMap.Layers> <igMap:MapLayer x:Name="trucks"/> </igMap:XamMap.Layers> </igMap:XamMap>
And the code behind:
public partial class MainPage : UserControl { DispatcherTimer _timer = new DispatcherTimer(); TruckEmulator _emul = new TruckEmulator(); public MainPage() { InitializeComponent(); _timer.Interval = TimeSpan.FromSeconds(.5); _timer.Tick += Timer_Tick; _timer.Start(); this.Loaded += new RoutedEventHandler(MainPage_Loaded); } void MainPage_Loaded(object sender, RoutedEventArgs e) { InitMapCoordinates(); } void Timer_Tick(object sender, EventArgs e) { double x; double y; _emul.GetCurrentCoordinates(out x, out y); MapLayer truckLayer = theMap.Layers[0]; if (truckLayer.WorldRect.IsEmpty) { truckLayer.WorldRect = theMap.WorldRect; } SymbolElement ele = truckLayer.Elements.OfType<SymbolElement>() .FirstOrDefault(); if (ele == null) { ele = new SymbolElement(); ele.SymbolSize = 5; ele.SymbolType = MapSymbolType.Bubble; } ele.SymbolOrigin = theMap.MapProjection .ProjectToMap(new Point(x, y)); if (!truckLayer.Elements.Contains(ele)) { truckLayer.Elements.Add(ele); } } private void InitMapCoordinates() { // define world dimensions Point worldTopLeft = new Point(-180, 90); Point worldBottomRight = new Point(180, -90); // Convert Geodetic to Cartesian coordinates Point winTopLeft = theMap.MapProjection.ProjectToMap(worldTopLeft); Point winBottomRight = theMap.MapProjection.ProjectToMap(worldBottomRight); // Create Rect structure the map control's WindowRect and WorldRect Rect winRect = new Rect() { X = Math.Min(winTopLeft.X, winBottomRight.X), Y = Math.Min(winTopLeft.Y, winBottomRight.Y), Width = Math.Abs(winTopLeft.X - winBottomRight.X), Height = Math.Abs(winTopLeft.Y - winBottomRight.Y) }; theMap.IsAutoWorldRect = false; theMap.WindowZoomMaximum = 80; // Change the map control's WindowRect and WorldRect theMap.WindowRect = theMap.WorldRect = winRect; } } public class TruckEmulator { private double _currentLat = 40.29029630058813; private double _currentLong = -74.55051898956299; public void GetCurrentCoordinates(out double x, out double y) { RandomlyMove(); x = _currentLong; y = _currentLat; } private Random _rand = new Random(); private void RandomlyMove() { if (_rand.NextDouble() > .5) { _currentLat += _rand.NextDouble() * .001; } else { _currentLat -= _rand.NextDouble() * .001; } if (_rand.NextDouble() > .5) { _currentLong += _rand.NextDouble() * .001; } else { _currentLong -= _rand.NextDouble() * .001; } } }
Hope this helps!-Graham
