410
BeforeRowDeletedHandler and multipule selections
the following code gets exectuted for each row rather than the whole selection, is there a better handler or better way to handle this withing the BeforeRowDeletedHandler?
Code:
function UltraWebGrid1_BeforeRowDeletedHandler(gridName, rowId){
    return !confirm("Are you sure you want to delete this selection?");
  • 410
     Guess I should RTFM.
    // needed to save a reference to
    // the user's answer in the confirm box
    var del = true;
    function UltraWebGrid1_KeyDownHandler(gridName, cellId, key){
    // if user hits delete key set deleting
    // to false so confirm box is shown
    if(key == 46)
    deleting = false;
    function UltraWebGrid1_AfterRowDeletedHandler(gridName, rowId){
    // set deleting to true so when deleting
    // multiple rows confirm is shown only once
    deleting = true;
    del = true;
    if(!deleting) // used to determine if confirm box has shown yet
    // show the confirm box
    del = confirm("You sure you want to delete row(s)");
    // set deleting to true so confirm is not shown again
    deleting = true
    // returning true cancels the event so return the opposite
    // of what the user selected in the confirm box
    return !del;
