hi
It works fine in 10.220102.1018, after u upgraded to 10.2.20102.2091. unhandled exception occured. i am not able to find the solution
Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.] Infragistics.Web.UI.Framework.AppSettings.get__initialized() +121 Infragistics.Web.UI.Framework.AppSettings.Initialize() +48 Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.OnInit(EventArgs e) +105 Infragistics.Web.UI.GridControls.WebDataGrid.OnInit(EventArgs e) +37 System.Web.UI.Control.InitRecursive(Control namingContainer) +140 System.Web.UI.Control.InitRecursive(Control namingContainer) +311 System.Web.UI.Control.InitRecursive(Control namingContainer) +311 System.Web.UI.Control.InitRecursive(Control namingContainer) +311 System.Web.UI.Control.InitRecursive(Control namingContainer) +311 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +480
The fix will be in the next service release which is currently scheduled for November 15, 2010. You can review the schedule for service releases at http://ko.infragistics.com/support/service-releases.aspx#ServiceReleases.
Let me know if you have any questions with this matter.
Sincerely,Duane HoytDeveloper Support Engineer, MCTSInfragisticshttp://ko.infragistics.com/support
Hallo,
I got the Service Release 2105. In this version there comes no exception but my design is not loaded complete. WebPanel is not showen correct.
In my case the exception occured loading a WebPanel. After update to 2105 it seams that there is only a try catch around this. For me it is not fixed. I already created a support request.
This issue is logged in development with issue id#37439. This issue is already fixed by development. The next service release includes the resolution for this issue. Here is the link to service release schedule for next service release:
<http://ko.infragistics.com/support/service-releases.aspx#ServiceReleases>
Hope this helps.
Bhadresh
I resolved this by contacting my company's product manager at Infragistics and receiving a yet-to-be
released service pack for WebClient (10.2.20102.2105). Apparently it is a code flaw in the previous service pack.
Suggest you do the same.
I am having the same issue too.
I figured out that the bug is resolved removing following line of config file:
<infragistics.web styleSetName="Default" styleSetPath="~/App_Themes/Deichmann/ig_res" />
But that's not the solution. Has anybody an idea why this happens? Any solution?
