1115
xamgrid columlayout look
I have a grid with 3 different types of child data in columnlayouts.  To make it visually easier to view, I thought I should vary the style of each child area.
I am assuming I would add a CellStyle to the ColumnLayout section, and define it somewhere as a resource.
Do you have an example I can base it on?
  • 40030
    I don't have a specific sample.
    However, you are correct in your assumption. Simply setting the CellStyle property for each ColumnLayout will do the trick.
    The CellStyle property is expecting a Style of type CellControl.
    The following sample shows an example of a custom CellControl style being used on the Root level of the XamGrid:
    https://ko.infragistics.com/samples/silverlight
    Hope this helps,
    -SteveZ
