This is the format that I want to use:
A-1234L-1234
How can I set it up so that the letter A and L always will appear and be at that location? Thanks!
Hi tangolp,
It has been a while since your post, however in case you still need help I will be glad to assist you.
The InputMask setting you are looking for is as follows:
WebMaskEditor1.InputMask = "\\A-0000\\L-0000";
You can find more information about the different options which are available for setting the input mask at:
http://samples.infragistics.com/aspnet/Samples/WebEditors/EditingAndSelection/MaskEditorBuildingMasks/Default.aspx?cn=editors&sid=17a4e6ad-ebd4-4220-927c-05434e1d430a
Please contact me if you have any questions.
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
