400
Chart Series Overlap
We are having a problem with the stacked bar chart where the series are being constrained to the XAxis label position.
Below is an example chart. The series data overlap only on one XAxis label yet the series show the data overlapping completely.
Here is the data being represented by this chart. As you can see the data only overlap on 48/2010 yet the chart has overlapping data on 40/201, 41/201 etc. We should see a chart starting with blue bars, an overlapping 48/2010 bar and then the rest of the red bars.
Item Label=39/2010, Item Value=0
Item Label=40/2010, Item Value=10
Item Label=41/2010, Item Value=8
Item Label=42/2010, Item Value=10
Item Label=43/2010, Item Value=8
Item Label=44/2010, Item Value=10
Item Label=45/2010, Item Value=8
Item Label=46/2010, Item Value=10
Item Label=47/2010, Item Value=8
Item Label=48/2010, Item Value=4
Label: Second Clin
Item Label=48/2010, Item Value=12
Item Label=49/2010, Item Value=16
Item Label=50/2010, Item Value=20
Item Label=51/2010, Item Value=16
Item Label=52/2010, Item Value=20
Item Label=52/2011, Item Value=0
Item Label=1/2011, Item Value=16
Item Label=2/2011, Item Value=20
Item Label=3/2011, Item Value=16
Item Label=4/2011, Item Value=20
Item Label=5/2011, Item Value=4
Am I missing something obvious?
Thanks for you help.
