I have a set of tables that I'd like to display using the timeline control with a line or column chart plotting the series values. Each series would have a column containing timeline values, and one or more columns containing datapoint values.
I would like to be able to add a chart to the timeline at the proper start/end dates of the table's timeline values, and plot the datapoints along that chart using line and/or column chart types.
In short, is it possible to lay chart controls onto the timeline control such that they play nice together?
- The timelines of the various tables that would be plotted may or may not overlap. I would want to allow the user to vertically separate the charts when they do overlap, or overlap the charts.
- I want to be able to use the zoom functionality of the timeline to zoon in & out of the chart data.
- I want to be able to click and drag the charts and slide them left or right to be able to "slide" the dates of the table timeline up or down.
- I want to be able to click and drag the left or right edges of the chart to extend or delete the dates of the timeline.
This feature request is not something we’d be able to consider before 13.1, so until then you can see this blog:
http://ko.infragistics.com/community/blogs/kiril_matev/archive/2011/07/28/using-xamtimeline-and-xamdatachart-to-build-an-annotated-view-of-your-time-series-data.aspx
where Kiril attached a sample where he combined those two controls.
is this feature available now? i would like to plot a column chart within a xamtimeline. Any way to achieve this? Thanks
Thank you for submitting your feature request. It’s been added it to our product backlog. There isn’t a projected release date for it right now.
Megan Sheehan
Sr. Product Manager
Is there any news about this ?
For now we don’t have built-in functionality for combining Timeline with a Chart. You can submit a feature request for that here: http://devcenter.infragistics.com/protected/requestfeature.aspx
