115
UltraWebGrid, set focus to cell after edit problem/question.
Hi all,
I'm having troubles setting focus to the next cell in my grid. Here is my situation:
I have a UltraWegGrid that contains studentnames and multiple columns for grades they score on tests. If a user enters a score , the cell below the one just used should become active. This should happen after a TAB, ENTER of maybe even a keydown keypress.
I have found this example:
http://forums.infragistics.com/forums/p/12988/48099.aspx#48099
Wich pointed me to the AfterExitModeHandler. (see code below). This one works, but only when TAB is pressed!! If i hit enter the cell below will become SELECTED, but not Editable?!
how can i make the Enterkey or the keydown key respont to this piece of code?
Can i fire this event from the KeyDownEvenHandler? (can events be nested, or how should i call that?)
I look forward hearing from you
Cheers
Eelko
code from link:
function AfterExitEditMode(gridID, cellID)
    var grid = igtbl_getGridById(gridID);
    var cell = igtbl_getCellById(cellID);
    var cellIndex = cell.Index;
    var rowIndex = cell.Row.getIndex();
    if (cellIndex > 0)
        cellIndex--;
    var newCellID = gridID + "_rc_" + (rowIndex + 1) + "_" + cellIndex;
    var newCell = igtbl_getCellById(newCellID);
    if (newCell != null){
        newCell.activate();
