Hi every body am using infragistics2007.v3
in my solution am using am using two webdatechoosers..one is using in search criteria and another one is using in gridview
as shown in figure above.. based on entry date i am getting values in WebGrid.. and in the from Date I am editing the data using another webdate Chooser...but if i click the cell it is not showing whatever Value in the Grid,it is showing some other value..like shown below
am using the below code
protected
void Page_Load(object sender, EventArgs
e)
SubscriberId = Session[
"strSubscriptionId"
].ToString();
Conn =
new SqlConnection
ConnAlter =
Conn.ConnectionString = Session[
"strDimDbConStr"
ConnAlter.ConnectionString = Session[
MDDb = Session[
"strMDDbName"
SecDb = Session[
"strSecDbName"
Conn.Open();
getFilter();
if
(!IsPostBack)
UltraWebGrid1.DataSource = ds.Tables[0];
UltraWebGrid1.DataBind();
UltraWebGrid1.Columns[6].AllowUpdate = Infragistics.WebUI.UltraWebGrid.
.Yes;
UltraWebGrid1.Columns[6].DataType =
UltraWebGrid1.Columns[6].Type = Infragistics.WebUI.UltraWebGrid.
.Custom;
UltraWebGrid1.Columns[6].EditorControlID = WebDateChooser1.UniqueID;
WebDateChooser1.Format = Infragistics.WebUI.WebSchedule.
.Short;
please suggest me some solution............
Hi thanx for your reply...sorry i given wrong image..now i am given below the right image and details about my need...please go through this and give me some solution
as shown in figure above.. based on Entry date i am getting values in WebGrid.. Based on the EntryDate- 14/09/2010...my FromDate Value is 25/09/2010...i hope u understand upto here,
Now i want to edit my FromDate Column in the grid using EditorControls.i.e WebDateChooser2...now problem is if i click the EditorControl in the Grid,it is not showing CurrentDate,it is Showing SomeOther Date like Below...
Now EntryDate-14/09/2010
FromDate-09/02/2010
now what i need is i want to display the CurrentDate, when i click the EditorControl in the Grid
this.WebDateChooser1.Format = Infragistics.WebUI.WebSchedule.DateFormat.Short;
System.Globalization.
CultureInfo c = new System.Globalization.CultureInfo("en-US");
c.DateTimeFormat.DateSeparator =
c.DateTimeFormat.ShortDatePattern =
"dd/MM/yyyy";
this.WebDateChooser1.CalendarLayout.Culture = c;
this.WebDateChooser2.CalendarLayout.Culture = c;
void btnAccept_Click(object sender, EventArgs
UltraWebGrid1.Columns[0].Width =
Unit.Pixel(115);
UltraWebGrid1.Columns[1].Width =
UltraWebGrid1.Columns[2].Width =
UltraWebGrid1.Columns[3].Width =
Unit.Pixel(100);
UltraWebGrid1.Columns[4].Width =
UltraWebGrid1.Columns[5].Width =
UltraWebGrid1.Columns[6].Width =
UltraWebGrid1.Columns[7].Width =
if (WebDateChooser1.Visible == false)
true;
AllowUpdate.Yes;
"System.DateTime";
ColumnType.Custom;
"WebDateChooser1";
DateFormat.Short;
if (dd_StyleCode.Visible == false)
UltraWebGrid1.Columns[0].AllowUpdate = Infragistics.WebUI.UltraWebGrid.
UltraWebGrid1.Columns[0].DataType =
"System.String";
UltraWebGrid1.Columns[0].Type = Infragistics.WebUI.UltraWebGrid.
ColumnType.DropDownList;
UltraWebGrid1.Columns[0].EditorControlID =
"dd_StyleCode";
For as far as i see the date in the grid matched the date in de datechooser.Your grid displays 09-02-2011Your datepicker displays February, 9th 2011What's not matching? What other value do you mean. If this still is a problem please be more specific. and also make sure you parse dates in the correct culture!
happy coding
