Hi everybody, i am using Infra2007.V3
in my solution am using am using two webdatechoosers..one is using in search criteria and another one is using in gridview
as shown in figure above.. based on Entry date i am getting values in WebGrid.. Based on the EntryDate- 14/09/2010...my FromDate Value is 25/09/2010...i hope u understand upto here,
Now i want to edit my FromDate Column in the grid using EditorControls.i.e WebDateChooser2...now problem is if i click the EditorControl in the Grid,it is not showing CurrentDate,it is Showing SomeOther Date like Below...
Now EntryDate-14/09/2010
FromDate-09/02/2010
now what i need is i want to display the CurrentDate, when i click the EditorControl in the Grid
am using the below code
void Page_Load(object sender, EventArgs
e)
if
(!IsPostBack)
this.WebDateChooser1.Format = Infragistics.WebUI.WebSchedule.DateFormat.Short;
System.Globalization.
CultureInfo c = new System.Globalization.CultureInfo("en-US");
c.DateTimeFormat.DateSeparator =
c.DateTimeFormat.ShortDatePattern =
"dd/MM/yyyy";
this.WebDateChooser1.CalendarLayout.Culture = c;
this.WebDateChooser2.CalendarLayout.Culture = c;
void btnAccept_Click(object sender, EventArgs
Unit.Pixel(115);
UltraWebGrid1.Columns[1].Width =
UltraWebGrid1.Columns[2].Width =
UltraWebGrid1.Columns[3].Width =
Unit.Pixel(100);
UltraWebGrid1.Columns[4].Width =
UltraWebGrid1.Columns[5].Width =
UltraWebGrid1.Columns[6].Width =
UltraWebGrid1.Columns[7].Width =
if (WebDateChooser1.Visible == false)
true;
UltraWebGrid1.Columns[6].AllowUpdate = Infragistics.WebUI.UltraWebGrid.
AllowUpdate.Yes;
UltraWebGrid1.Columns[6].DataType =
"System.DateTime";
UltraWebGrid1.Columns[6].Type = Infragistics.WebUI.UltraWebGrid.
ColumnType.Custom;
UltraWebGrid1.Columns[6].EditorControlID =
"WebDateChooser1";
DateFormat.Short;
if (dd_StyleCode.Visible == false)
UltraWebGrid1.Columns[0].AllowUpdate = Infragistics.WebUI.UltraWebGrid.
UltraWebGrid1.Columns[0].DataType =
"System.String";
UltraWebGrid1.Columns[0].Type = Infragistics.WebUI.UltraWebGrid.
ColumnType.DropDownList;
UltraWebGrid1.Columns[0].EditorControlID =
"dd_StyleCode";
UltraWebGrid1.DataSource = ds.Tables[0];
UltraWebGrid1.DataBind();
UltraWebGrid1.Columns[0].Width =
Hello Naag C,
I may need more information from you.
Please attach the markup and the associated program.
Thank you.
