745
How to assign value for Editor Control using JavaScript
Hi ... I am using Infr2007v.3, In my application i am using a wedgrid..in that i am assigning a webdate chooser for a cell like below
UltraWebGrid1.Columns[6].AllowUpdate = Infragistics.WebUI.UltraWebGrid.
AllowUpdate
.Yes;
UltraWebGrid1.Columns[6].DataType =
"System.DateTime"
UltraWebGrid1.Columns[6].Type = Infragistics.WebUI.UltraWebGrid.
ColumnType
.Custom;
UltraWebGrid1.Columns[6].EditorControlID =
"WebDateChooser2"
i want to edit the data of column[6] using webdate Chooser...i want to display the current Date ..how can i do this using JavaScript
  • 49378
    Hi Naag C,
    It has been some time since your post, however in case you still need assistance with this I would be glad to help.
    Obviously I am not aware of your particular implementation specifics, but you should be able to change the values for all cells using code similar to:
    for(int i=0; i<igtbl_getGridById('UltraWebGrid1').Rows.length ; i++) {
    igtbl_getGridById(
    'UltraWebGrid1').Rows.getRow(i).getCell(6).setValue(newValue);
    where newValue in your case should be some date value.
    Please contact me if you have any questions.
    Best Regards,
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
