The ItemsSource of my Grid is a IEnumerable<SampleObject>.
The SampleObject consist of Guid id, String str1, String str2 and a ObservableCollection<SampleDynObject> dy.
The SampleDynObject consist of one strTest property.
After the creation of the xamWebGrid, I create TextColumns for the id, str1 and str2 data.
For the data from the SampleDynObject, I create UnboundColumns
UnboundColumn col = new UnboundColumn() { Key = Guid.NewGuid().ToString(), ValueConverter = new SampleConverter(), ValueConverterParameter = i };
The SampleConverter looks like this:
public class SampleConverter : IValueConverter { public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture) { SampleObject so = value as SampleObject; int index = Int32.Parse(parameter.ToString()); //This is the index of the SampleObject's child collection if (so != null) { return so.dy[index].strTest; } return null; } public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture) { throw new NotImplementedException(); } }
The question is: I tried to use the ContainingConditionalFormatRule, but it worked only on the TextColumns and not on the UnboundColumns.
My idea was to manually check the Rule by adding a second ValueConverter, but it seems to be only possible in the XAML-Markup and not by code.
So, how can I format the Background of the Cells.
If I set the key to dy, it works only if "dy" has only one element, because every element has to be displayed in a separate column.
If I try to create more then one column with the key, a DuplicateColumnKeyException occurs: The following key has been defined more than once: dy.
You should be able to set the key to "dy" (the name of your property) then use the value converter to get the index value within that collection.
Also, just as an FYI, in our 2010 Volumr 3 release we are adding support for indexer key values so you will be able to specify a key like "dy[i].strTest" directly on the column.
Let me know if that works for you.
Devin
Thank you for your answer.
I tried it, but then it required a key, but I don't know which key I shall use for binding it to the Collection objects.
I also tried to use a random key, but then the following exception occured:
The following key(s) do not correspond with the DataSource: "3d83f804-a1a8-4b77-b479-abe3494ff4cf". If you'd like to add additional columns, please use the UnboundColumn type.
I am curious why you are using an unbound column for this? I would suggest using a standard TextColumn instead and assigning the value converter to that.
