I am using an ultrawebgrid 2009.2
I am using the following to bind my data to the ultrawebgrid:
uwg.DataSource = refdatauwg.DataBind()uwg.EnableAppStyling = Infragistics.WebUI.[Shared].DefaultableBoolean.[True]uwg.StyleSetName = "Claymation"If (id > 0) Then uwg.DisplayLayout.SelectedRows.Clear() If (Not uwg.Rows.FromDataKey(New Object() {id}) Is Nothing) Then uwg.Rows.FromDataKey(New Object() {id}).Selected = True uwg.Rows.FromDataKey(New Object() {id}).Activated = True uwg.Rows.FromDataKey(New Object() {id}).Activate() End IfEnd If
The first time I load the grid, an id has been selected from another page I can see the row highlighted.
Now when I go to the next page and go back to the page the row is not highlighted. It goes into the test, if I inspect uwg.DisplayLayout.SelectedRows, the correct row has been selected, but it seems that it doesn't apply the selected row style any more.
Anyone a clue what I am doing wrong ??
Hi estanito,
It has been a while since your post, however in case you still need assistance I would be glad to help.
In order to ensure that your style is persisted through page switching, the Browser and LoadOnDemand properties of you grid should not be set to XML as styles are not reapplied when communication with the server takes place in that mode.
Please contact me if you have any questions.
Best Regards,Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
