795
populating custom or unbound column from webservice call
My grid is bound to a collection of SrvItem objects, unfortunately, I need to also display some ancillary data in each row the requires another webservice lookup using one of the fields of the SrvItem object.  At first, I thought I'd use an Unbound column and a ValueConverter, but that won't work due to the the asynchronous nature of WCF Data Service calls. Basically I;d need to do something like this to get the data I need:
                DataServiceQuery<CIRCUIT> query = (DataServiceQuery<CIRCUIT>)from c in MainPage.context.CIRCUITs.Expand("EQUIPMENTs") where c.PCIRCUITGROUP_Id == item.CCIRCUITGROUP_Id select c;
                query.BeginExecute(result => App.Current.RootVisual.Dispatcher.BeginInvoke(() =>
                            data = query.EndExecute(result).ToList();  // get the data
                           // then massage the data and display it in the unbound or custom column
                        }), null);
Since a ValueConverter won't work, could I perhaps create a custom column type and somehow bind it to item.CCIRCUITGROUP_Id but make it display a custom value based on the results of the async query?
