I have attached a simple project recreating my scenario.
Version : 10.2.20102.2005
When I click into different cells back and forth I get an unhandled exception
"Operation is not valid due to the current state of the object"
More of the exception information:
System.Windows.Data.BindingExpression.UpdateSource() at Infragistics.Controls.Grids.CellControl.EvaluateEditingBindings() at Infragistics.Controls.Grids.Cell.ExitEditMode(Object newValue, Boolean editingCanceled) at Infragistics.Controls.Grids.XamGrid.ExitEditModeInternal(Boolean cancel) at Infragistics.Controls.Grids.XamGrid.SetActiveCell(CellBase cell, CellAlignment alignment, InvokeAction action, Boolean allowSelection, Boolean setFocus, Boolean scrollIntoView) at Infragistics.Controls.Grids.XamGrid.SetActiveCell(CellBase cell, CellAlignment alignment, InvokeAction action, Boolean allowSelection, Boolean scrollIntoView) at Infragistics.Controls.Grids.XamGrid.SetActiveCell(CellBase cell, CellAlignment alignment, InvokeAction action, Boolean allowSelection) at Infragistics.Controls.Grids.Cell.OnCellMouseDown(MouseEventArgs e) at Infragistics.Controls.Grids.XamGrid.XamWebGrid_MouseLeftButtonDown(Object sender, MouseButtonEventArgs e) at MS.Internal.CoreInvokeHandler.InvokeEventHandler(Int32 typeIndex, Delegate handlerDelegate, Object sender, Object args) at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName)
Please Help!
Check out the answer in the following thread, as this is basically the same issue:
https://ko.infragistics.com/community/forums/f/retired-products-and-controls/45734/binding-to-dependency-property-of-usercontrol/252629#252629
