190
Shapefile not working properly with open streets map
Hello!
I've been evaluating the xamMap and I have a problem with projection, the layer from my shapefile is not where it's suposed to be and it also seems smaller than it should be. The shapefile works fine in Arcgis explorer, it also works fine in Telerik's map component after beeing converted to kml.
The shape file wont display at all if I don't add the <igMap:SphericalMercator /> in the shapefile reader. And it looks like to me that the projection on the shapefile is of that type.
If I set the MapProjectionType to Equirectangular the shapefile display, but then the openstreetmap doesnt.
I have not been able to try this using Bing's free maps instead of openstreetmap since I can't find any help on how to do that when you don't have a username and password for bing that you get with the pay version.
//Thomas
My code is as below
 <igMap:XamMap
Grid.Column="0"
MapProjectionType="SphericalMercator"
HorizontalAlignment="Left"
Name="xamMap1"
VerticalAlignment="Top"
Width="600"
Height="836"
ElementClick="xamMap1_ElementClick"
IsClickable="True"
ViewportBackground="Transparent" BorderBrush="Black" BorderThickness="2" >
<igMap:XamMap.MapTileSource>
<igMap:OpenStreetMapTileSource x:Name="openStreetsTileSource" />
</igMap:XamMap.MapTileSource>
<igMap:XamMap.Layers>
<igMap:MapLayer x:Name="mapLayer" FillMode="None" Fill="Transparent" >
<igMap:MapLayer.Reader>
<igMap:ShapeFileReader Uri="../Shapefiles/Sweden_county07">
<igMap:ShapeFileReader.CoordinateSystem>
<igMap:CoordinateSystem>
<igMap:CoordinateSystem.Projection>
</igMap:CoordinateSystem.Projection>
</igMap:CoordinateSystem>
</igMap:ShapeFileReader.CoordinateSystem>
</igMap:ShapeFileReader>
</igMap:MapLayer.Reader>
</igMap:MapLayer>
</igMap:XamMap.Layers>
</igMap:XamMap>
