When + sign is clicked from a row in xamGrid, then only I want to generate hierarchal data for the row (i.e. for the selected row from code behind I want to dynamically create drill down data like column layout populate it and display it for the row).
Please, check this post for the relevant information.
HTH,
I want to implement Virtual Collection with my hierarcal data i.e. for data inside column layout. Kindly suggest me on this.
Bharath
This looks like some solution for me. Thanks for the response.
HI,
I created a sample application that dynamically gets data.
Sincerely,
Matt Developer Support Engineer
Please refer the following post as I think it may help you with your request:
https://ko.infragistics.com/community/forums/f/retired-products-and-controls/30041/how-to-create-hierrarchical-structure-of-columns-in-runtime/156797#156797
