i'd like to know where i can find the default control template of the cells of a TextColumn. I Disassembled the Infragistics.Silverlight.XamWebGrid.v10.1.dll, and looked at generic.xaml, but i can't figure out where it is.
I'm lookin for this because i need to know if TextBoxes are rendered in the XamWebgrid in a non-edit mode.
Thanx.
Thanx, that was what i was looking for.
I meant i wanted to know if a Textbox control is present and shown on screen in the template of the cell control even in non-edit mode. I hope it's clear enough, but it's hard to explain in english for me :)
You can see all of the various controls that compose the XamGrid in this help topic:
http://help.infragistics.com/NetAdvantage/Silverlight/2010.2/CLR4.0/?page=SL_DesignersGuide_Styling_Points_for_xamGrid.html
Your looking for a control called CellControl. You can use Blend to create a default copy of this control, or you can look in the Infragistics Start menu folder for an item called "Default Styles", which points to a folder where we drop the default XAML resource dictionary files used by all of our controls.
I am not entirely sure I understand what you mean by "rendered in a non-edit mode".
Devin
