How can I do that ?
once I click on a button, I make a xmlhttprequest in js which update sg, rigth after that I would like to refresh a panel
how can I do that ?
thx
finally it works as wished.
on the client side, I use this panel.refresh()
on the server side, this event is called
WebAsyncRefreshPanel1_ContentRefresh
I repopulate and rebind the needed control and it's working perfectly
Thx
ok but as you said, it's on the client side ...
I want to fetch the new datas from the server
The situation is ...
on one tab, if I make sg , I add datas in the database
and I would like to refresh the tab2 without reloading the whole page
panelName is your webAsyncRefreshPanel Id and
you need to have your script manager enabled on your aspx page. Then using ig$ you can get the warp panel object.
var warp = ig$(panelName); if(warp) warp.refresh(); //this command will refresh panel on client side.
