Is there a way have an editable XamComboEditor act like a readonly XamComboEditor when the user clicks on the control and it pops open the list ?
I think what you going to have to do here is use the GotFocus event and manuall open the dropdown. Something like this:
<ig:XamComboEditor ItemsSource="{Binding}" DisplayMemberPath="Name" OpenDropDownOnTyping="True" CustomValueEnteredAction="Add" GotFocus="XamComboEditor_GotFocus" />
private void XamComboEditor_GotFocus(object sender, RoutedEventArgs e){ ((Infragistics.Controls.Editors.XamComboEditor)sender).IsDropDownOpen = true;}
This will pop open the dropdown as soon as the control gets focus, even if the user has not typed anything.
Devin
Hi gmcalab,
when you click on drop down arrow of editable XamComboEditor the list opens and you can type text in TextBox to filter the list.
Hope that helps.
Best regards,Milena MitovaSoftware Engineer in Test INetAdvantage for Silverlight LoB
