Is there a way have an editable XamComboEditor act like a readonly XamComboEditor when the user clicks on the control and it pops open the list ?
SO basically when I click on the control, the list will pop open just like the readonly situation, and I can begin filtering....
This solved my problem, listening for GotFocus for the XamComboEditor and then setting IsDropDownOpen to True.
uiElement.GotFocus += (e, args) =>{ ((XamComboEditor)uiElement).IsDropDownOpen = true;};
Setting IsEditable does not make this work. Setting this to false makes it so I can type into the combobox to begin filtering which is not what I want. I want to be able to type in the combo box. What I wanted to add it initially when the user clicks on the combobox before typing, have the list open up. That is what the readonly one will do.
HI,
Try setting the XamComboEditor's isEditable property to false.
IsEditable="False"
Here is a help link
http://help.infragistics.com/NetAdvantage/Silverlight/2010.2/CLR4.0/?page=InfragisticsSL4.Controls.Editors.XamComboEditor.v10.2~Infragistics.Controls.Editors.XamComboEditor~IsEditable.html
Sincerely, MattDeveloper Support Engineer
