How can I configure XamWebNumericEditor to work as follows (basically an Id field w/no formatting):
I currently have these issues:
Hello Geoff,
sorry for the late response.
I have tried to achieve the case you have described. I managed to set the value type in XAML to Int64 like follows:
xmlns:sys="clr-namespace:System;assembly=mscorlib"//...<ig:XamWebNumericEditor x:Name="editor" Width="120" Height="25" PromptChar=" " />
By doing so the no comma is displayed. It seams that the only way not to display any promptChar is to set it to " ".
However this causes last symbols to be cut off(as you have pointed out). This seams to be a bug that is why I have logged this issue with development under ID: 57651 and they are currently investigating it. I have also created a support ticket for you (Case ID: CAS-55022-CYBLC7) and lave linked the development work item to it so that you are notified when it is resolved and available for download from our website:
https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
HTH, please let me know if I can assist you further.
